AirPort Anteni
3 Cevap 4 Puan |
What adhesive is safe to use for keyboard rubber cap under spacebar? |
10 Cevap 6 Puan |
Thunderbolt Port not working correctly! |
7 Cevap 5 Puan |
MacBook Pro 17" early 2011, possible revival? |
4 Cevap 3 Puan |
Why is my new battery's health dropping so quickly!? |
Parçalar
- Apple MagSafe 1 AC Adapter
- MacBook and MacBook Pro Unibody Plastic Feet
- MacBook Pro Unibody Lower Case Screw Set
- 2.5" Hard Drive Enclosure with USB 3.0 Cable
- MacBook and MacBook Pro (Non-Retina) SSD Upgrade Kit
- MacBook Pro Unibody (A1278, A1286, A1297) Key Caps
- MacBook Pro Unibody Lower Case Screw and Foot Kit
- MacBook Pro 17" Unibody (Early 2009-Late 2011) Keyboard
Aletler
- Spudger
- Essential Electronics Toolkit
- Tweezers
- iFixit Opening Tool
- iFixit Opening Picks (Set of 6)
- Phillips #00 Screwdriver
- iFixit Thermal Paste
- Heat Gun
- T5 Torx Screwdriver
- Tri-point Y0 Screwdriver
- Phillips #000 Screwdriver
- Heavy-Duty Suction Cups (Pair)
- Tri-point Y1 Screwdriver
- T6 Torx Screwdriver
- Adhesive Cleanup Kit (Set of 12)
- Arctic Silver ArctiClean
Model
A1297 (EMC 2272 MacBookPro5,2) 2.66 GHz (Early 2009), A1297 (EMC 2272 MacBookPro5,2) 2.93 GHz (Early 2009), A1297 (EMC 2329 MacBookPro5,2) 2.8 GHz (Mid 2009), A1297 (EMC 2329 MacBookPro5,2) 3.06 GHz (Mid 2009), A1297 (EMC 2352 MacBookPro6,1) 2.53 GHz (Mid 2010), A1297 (EMC 2352 MacBookPro6,1) 2.66 GHz (Mid 2010), A1297 (EMC 2352 MacBookPro6,1) 2.8 GHz (Mid 2010), A1297 (EMC 2352-1 MacBookPro8,3) 2.2 GHz (Early 2011), A1297 (EMC 2352-1 MacBookPro8,3) 2.3 GHz (Early 2011), A1297 (EMC 2564 MacBookPro8,3) 2.4 GHz Late 2011, A1297 (EMC 2564 MacBookPro8,3) 2.5 GHz Late 2011
Yükseltmeler
MacBook Pro 17" Unibody modelinde maliyet etkin bir şekilde yükseltilebilecek birçok bileşen bulunmaktadır.
- Bellek: MacBook Pro 17" Unibody modelleri standart olarak 4 GB ile gelir. MacBook Pro 17" Unibody cihazınız hâlâ orijinal RAM ile çalışıyorsa, 8 GB'a yükseltmek performans artışı sağlayacaktır. Kullanıcı testleri, Mavericks kurulumunun, uygun hız düşürme (downclocking) işlemiyle birleştirildiğinde 16 GB'a kadar yükseltmeye olanak tanıdığını kanıtlamıştır.
- Sabit Disk: 500 Gigabayt sabit diskler, MacBook Pro 17" Unibody ile standart olarak gelmiştir. Diski kolayca yükselterek 750 GB kapasiteli bir disk takabilirsiniz.
Kimlik Bilgileri ve Arka Plan
MacBook Pro 17" Unibody, Ocak 2009'da duyurulmuştur. MacBook Pro 17" Unibody, MacBook Unibody ve MacBook Pro 15" Unibody modelleri haricinde, diğer MacBook dizüstü bilgisayarlardan oldukça farklı görünür. MacBook Pro 17" Unibody, 13" veya 15" ekran yerine 17" ekrana sahip olmasıyla diğer iki modelden kolayca ayırt edilebilir.
MacBook'lar birbirine çok benzer görünme eğilimindedir ve herhangi bir yedek parça sipariş etmeden önce hangi cihaza sahip olduğunuzu bilmeniz önemlidir. Cihazınızı bu bölümdeki detaylarla karşılaştırarak kontrol edin. Eğer eşleşmiyorsa, modelinizi MacBook Pro 17" altında bulun ve sayfasındaki Kimlik Bilgileri bölümünü kontrol edin.
MacBook Pro 17" Unibody'nin kasası, kendinden önceki dizüstü bilgisayarlarda olduğu gibi alüminyumdan oluşur. Ancak kasa, MacBook Unibody ve MacBook Pro 15" Unibody modelleriyle aynı işlem izlenerek tek bir alüminyum bloktan üretilmiştir. Unibody revizyonu ayrıca, bir Apple dizüstü bilgisayarında daha önce hiç görülmemiş bazı özellikleri de beraberinde getirmiştir: çift ekran kartı (biri normal kullanım, diğeri grafik yoğun uygulamalar için), Mini DisplayPort (tam boy DVI ekran bağlantısının yerini almıştır) ve daha büyük sabit disk ve RAM kapasiteleri.
Teknik Özellikler
Her model için fabrika teknik özellikleri aşağıdaki bağlantılarda mevcuttur.
Ek Bilgiler
- iFixit: Sorun Giderme Rehberleri Listesi
- iFixit: Mac OS X HD Yeniden Kurulum İpuçları
- iFixit: Kendin Yap Dizüstü Bilgisayar Yükseltmeleri
- Wikipedia: MacBook Pro Sayfası
- Mactracker: Apple Ürün Teknik Özellikleri Uygulaması
- EveryMac: MacBook Pro Ürün Teknik Özellikleri
- Apple: MacBook Pro
- iFixit Blog: MacBook Pro 17" Unibody Sökümü
