Ana içeriğe geç
Sony tarafından 2009'da piyasaya sürülen 12,1 megapiksel, çek-çek dijital fotoğraf makinesi.
Camera will not retain date/time
When I power up my Sony W230 it gives me the option to set the clock and date or bypass it altogether. I set the date and time. I can then take photos. If I power it off and then on again, I get the same screen for setting the clock and date from. I have changed battery to freshly charged one... Reset to original settings... Formatted card... Switched out cards... Removed battery overnight... Nothing works. My camera continuously reverts back to Jan 1, 2009 12AM. If I set the clock and then take pics, the date and time is already back to Jan 1, 2009. I am assuming this camera has an internal battery which has died. Please help. Thanks
Bu iyi bir soru mu?
Puan 5
7 Yorum
Battery named in wirring BT900 its ML621 - coat 2-6 USD / ebay / aliexpress
tarafından
I have this issue too but with DSC-W810, where is backup battery located on mainboard because i don't see it?Help me please, thank you.
tarafından
Hi,
Mine is DSC-w630; I am facing with the same issue but no idea what the battery type is or basically how to disassemble the Camera!?
Any help or clue is really appreciated
Regards,
Nick
tarafından
search in google dsc w630 service manual and dowload it
battery type is ML621
tarafından
I have Sony A5100 with exactly same issue. I reset the date /time but it does not retain current date /time and keeps asking to reset date /time.
tarafından
2 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@treehugger58 you are correct. Your camera uses a RTC battery (Real Time Clock) to retain all the data. That battery is a 1-756-710-12 and is located on the ST-207 board.
Resim
Resim
Now, if you need to know how to get to it, use this manual DSC-W230 SM
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Thanks a million. This W230 is in my HomeBrew trail cam and takes great pics. I appreciate your help
tarafından
Yorum Ekle
Hi Seyed Farshad Zolfaghari,
Here is a video showing how to dis-assemble a Sony W630.
The video is in Portuguese, hopefully it will still be of some help to you.
At 5:54 minutes into the video the battery is clearly visible (at least I think that it is the battery). If it is a battery the type information should be printed on it.
Resim
(click on image to enlarge for better viewing)
Hopefully this is of some help
Puan 2
1 Yorum:
Appreciate it mate. Of course, that was helpful.
Cheers,
tarafından
Yorum Ekle
Hi @josephlittleton,
When you click on OFF does the check mark next to the word OFF disappear?
If so, the word may not change to ON, it just means that the function is no longer OFF i.e. it is now On and it probably means that the date and time will be superimposed on the image.
Does the Date icon come on if the check mark is not present when you try taking images etc?
Here’s an image of what I mean. Check mark is highlighted in red box
Resim
Puan 2
2 Yorum:
Many thanks for your help. Date/Time is at "Off" and I've tried to change to "On" but without success as it stays at "Off". This is probably why the date does not superimpose on the images that I take.
Many thanks
Joe
tarafından
Hi,
Does the check mark disappear when you click on OFF or not?
If it does then take a picture and see if the date and time is there.
I suspect that the word "ON" will NOT appear it will simply show either that "Off" is selected or not selected.
If "Off" is not selected it means that is is "ON"
tarafından
Yorum Ekle
Yanıtını ekle
CindiB sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 9,700
