Ana içeriğe geç
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Soru Tümünü görüntüle
Laptop will not charge?
So I bought a MacBook air from someone with intent on fixing it. I get home to charge it and it doesn't( that i knew already) so i started trouble shooting and i figured that it was the battery so i bought replacement and that didn't solve the problem! I can get it to charge but only if I unplug the battery and plug up the ac adapter wait for the computer to start booting and then plug up the battery!? and this method works on both batteries old and new. What is the issue I've never seen this before?!!!
Bu iyi bir soru mu?
Puan 0
4 Yorum
What light is the charger when the battery is connected, dim green?
tarafından
I can only get a light while the battery is unplugged; its a bright green and then it turns orange after i plug up the battery. i can't get a charge light no other way
tarafından
That's strange. Check the whole board for liquid damage and check the charging IC for any burnt pins too. It is able to communicate with the battery clearly, so its a bit of a weird one.
tarafından
Thank you I'll give that a try! My Coworker is selling me her 2014 air for cheep because of water damage so I'll salvage those parts and hopefully the I/O board is good and I'll swap those to see if thats the issue! I really appreciate your help!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I had this model in yesterday with the same issue. I replace the I/O board and fixed it: MacBook Air 13" Mid 2012 I/O Board Replacement
MacBook Air 13" (Mid 2012) I/O Board
MacBook Air 13" (Mid 2012) I/O Board Görseli
Ürün
$89.99
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I have had my macbook air’s left i/o board and flex cable replaced after spilling milk tea on it but after the replacement the battery won’t charge after a while?
tarafından
Yorum Ekle
Try to reset the SMC and PRAM
Puan 1
2 Yorum:
Sweet I'll give that a try! Thank you!
tarafından
Still no dice?! So weird maybe the I/O board?
tarafından
Yorum Ekle
Yanıtını ekle
Ray McGee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 110
