Ana içeriğe geç
The front burner will not turn off sometimes
I have a glasstop range and sometimes when I try to turn down the heat under a pot,
it does not turn down and sometimes takes several attempts to shut the burner off.
It just stays on very high temp
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Two Possible Problems: Your burner's gas valve has worn out and it leaks. It needs to be replaced. A leaky gas valve is a fire hazard. Or, the connector from the burner knob to the valve control has weakened. The plastic is in a shape that does not fully operate the valve. Both of these problems are easily replaceable.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Betty sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 19
