Ana içeriğe geç
Atari 2600 veya Atari Video Computer System (VCS), Eylül 1977'de piyasaya sürülen bir oyun konsoludur. 2600, MOS Technology 6507 işlemci kullanır ve oyunları depolamak için ROM kartuşlarından yararlanır.
The screen seems dark
I just found my old 2600 in my garage, I cleaned it up and even fixed one of the controllers that was broken inside, so when I plug it in and turn it on the screen seems a lot darker than I remember it looking, what could cause this? everything else works fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
@kazman72 how did you connect it to your TV and what TV are you using?
tarafından
I used the rca cable to the cable coax adapter method, I'm using a newer samsung hd tv.
tarafından
Did you check your RF switch on the back of the console? And the tip of the cord that goes into the console? Sometimes it gets dirty over time and doesn't get a good connection. I would suggest unplugging everything the get a qtip with rubbing alcohol and cleaning the connector on the console and the end of the cord. That works for me.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try checking the screen settings on your television. On my LG I can set different lighting settings for different inputs, and some cause the screen to appear darker than others. Each input on your television will have different pictureh modes so setting it on one input will not automatically transfer it over to another.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jonathan Kazarian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 902
