Ana içeriğe geç
Citroen'in süpermini sınıfı otomobilinin ilk nesli.
Reversing light comes on occasionally when breaking
Since having my reversing lights repaired at a garage, they come on occasionally when I break. Drivers behind me are worried! I can't recreate the fault when stationary tho. Help!
Bu iyi bir soru mu?
Puan 0
2 Yorum
does the reverse light work when you have it in reverse gear??
tarafından
Yep, reverse light works when in reverse gear and I can see it when it's stationary
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
If the work was carried out recently to repair the reversing lights by a garage, there should be some sort of guarantee on their workmanship, provided by them, even if it is only for 30 days etc.
Take the car back to them and explain the problem and show them as well (hopefully the problem will happen when you do this) and ask them to check it out, as it is causing problems for you..
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
sophie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 490
