Ana içeriğe geç
2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
120 Soru Tümünü görüntüle
Plastic cover removal or replacement
Does the plastic cover adhered to the battery inside the Macbook pro 13in retina early 2013 have to be replaced after being removed? I Ive tried just sticking the original back on but it doesn't stick very well. Can I just remove it?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you are referencing the cover the came with the new battery, it is just there to prevent the battery from sticking to things. It can be discarded after the battery is installed.
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
Sorry I should have done this to begin with but I attached a picture of the flap in question to the post. Thanks in advance!
tarafından
Sorry, difference piece of plastic. Those do not stick well, I use some Kaptan tape to hold it in place.
tarafından
Does that piece of plastic have a purpose or can it be removed all together?
tarafından
Keeps the bottom plate from contacting.
tarafından
Yorum Ekle
Yanıtını ekle
Alex Higgins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 281
