Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
RAM Upgrade 2133 MHz now having problems
Hi,
I have a MacBook Pro (13-inch, Mid 2012)
I had upgraded the RAM modules of my MacBook Pro to 2133 MHz Using Kingston's HyperX Impact RAM, I was using these in my system for more then 2 years, a few days back, I had some GPU issues so I removed my HyperX RAM modules and Reinstalled the original Apple RAM and gave it to Apple to repair.
Apple has now replaced the Logic Board, I then put back the HyperX RAM back in my system and it only shows me a solid power light when I turn on my Mac. It doesn't boot up or make any chime noise or anything, I don't know why this is happening,
The HyperX RAM were working fine for so long but after the logic board change out there giving me issues. I even tried my RAM modules in on someone else computer and the RAM works just fine. It's just not working in my computer!
What should I do?
Bu iyi bir soru mu?
Puan 1
3 Yorum
Is this the RAM you used? Kingston HyperX Impact RAM
Here's Apples RAM guide: MacBook Pro: How to remove or install memory
tarafından
tarafından
Same goes to mine... GPU glitches after few minutes, put back the 1600 MHz RAM its works fine. I used to put in 1866 MHz with no problem, no more...
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@mohur - When you start using RAM that is beyond the specs of what the system was designed to support you can get into some odd behaviors. Just because a company pushes a product as being better it may not be! Let me explain...
Think of it this way a given road has a speed limit of 35 MPH and lets say all of the cars that are on that road are at this exact speed. So having a car, bus, or truck makes no difference! As all of them run at this set speed. Now lets throw in a race car into the mix most can barely go 35 MPH as its just too slow! It spits and sputters as it tries to run at this slower speed. But on the open racetrack it can zoom!
RAM modules are very similar! The speed limit of the bus is set, you can't run faster than the bus (road). Yes, you can put in faster RAM. Doing it with the expectation you are going to get more or better performance is not really realistic.
OK lets dig deeper here by looking at the RAM's CAS speed of your RAM
What this system needs and your RAM:
Now look at your modules timing:
DDR3-1600 CL9-9-10 @1.35V or 1.5V
So depending on the given system's hardware you may encounter a problem as the range of the faster RAM is not as wide as the slower RAM. Your original systems logic board PCH may have had just enough range to support the faster RAM module unlike your current board. It's also likely Apple altered the timing a bit as that might have been one of the alterations needed to resolve the GPU problem it was facing.
References:
Bu yanıt yardımcı oldu mu?
Puan 3
8 Yorum:
Hi Dan is it possible to alter the Timing again.
tarafından
Sadly, I don't see that as a solution here. You would be giving up the graphics for the RAM. Best to sell the RAM and get the correct speed for the system.
tarafından
I agree with Dan.
tarafından
Hi Dan can i upgrade to DDR3L 1866MHz Hyperx , I'm currently using 1600 8Gb normal Kingston Ram, which i find really slow even for normal use open or shutting app and all , Compared to the 2133mhz
tarafından
Sadly, I think what you are seeing is mostly in your head ;-}
Give the vid a watch & read the second article:
- High Speed RAM - Is it Worth it? DDR3 1333MHz vs 2400MHz Test - Linus techtips
- Does RAM Speed Matter? DDR3-1600 VS. 1866, 2133, AND 2400 in Games
Both of these show there is no real improvement in using faster RAM in a desktop class system.
I would focus my efforts on the amount of RAM as that has a bigger bearing than the speed of the RAM. To put this into perspective a lean system (i.e.4 GB) will need to use the Drive for Virtual RAM which would be very slow Vs maximizing the RAM for the given use (i.e.16 GB).
tarafından
3 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
In electronics, or at least Macs, processor and speeds vary in the same model. They are based on minimums. But there are variants. Some run faster than rated and some run at the posted speed.
The recommended RAM for your machine is DDR3L at 1600 MHZ. You are really trying to push that. Also slots vary. At this point I would try just one stick at a time and try it in both slots.
You may have to go back to the recommended sticks.
Can you tell us why you are pushing your machine so hard and give a link as to where it's listed that this RAM will work in your machine so we can study it a bit.
Puan 3
5 Yorum:
Hi , i used to Use 2133 Mhz Ram on my Laptop for 2 years , now recently i had a GPU issue , so apple changed the logic Board, After Changing the Logic Board the when I install the Sticks on the New Logic Board, Only the Power Light turns on on the mac , nothing else. i don't understand why, it used to work before.
tarafından
2133 MHz on a DDR3L stick!! That's DDR4 speed! Too much, I agree with @mayer.
tarafından
No Its DDR3 HyperX Rams.
tarafından
ya But the question is that it used to work Before On my mac I Used it For more then 2 Years without any issue. Recently i had a GPU Issue so apple changed my logic board , after the new logic board the Ram Sticks aren't working.
tarafından
The fact it's only DDR3 is amazing. I have never seen clocks like that out of DDR3.
tarafından
Yorum Ekle
Yanıtını ekle
Mohur sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,164
