Ana içeriğe geç
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
615 Soru Tümünü görüntüle
Why does my Epson printer not copy
My Epson printer WF-2650 will not photocopy, the error message reads: "The Paper Source Setting Is Invalid" do you have any suggestions?
Bu iyi bir soru mu?
Puan 37
44 Yorum
Try changing paper type in setup from plain to matte this worked on my wf-2750
tarafından
I will give this a shot tonight.
tarafından
Thanks Christopher Burdett, that worked on my WF-2750 also.
tarafından
I have the wf-2630
tarafından
Praise the Epson answer God....been trying to print a simple single copy on this Epson WF-2750 (used to have XP-310).....changing to matte setting was the ticket!!!!! TY!
tarafından
39 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
I know its not an exact match but maybe this might help
https://epson.com/faq/SPT_C11CE36201~faq...
Bu yanıt yardımcı oldu mu?
Puan 12
27 Yorum:
I have the Epson workforce 2630 have tried everything to copy but keeps saying paper source invalid. Driving me made!!!!!
tarafından
I'VE GOT IT! Borderless option is NOT supported with plain paper! (Who knew?)
Hit Home
Select Copy
Switch layout option to WITH BORDER
COPY!!! HOORAY!
tarafından
Cheers works a treat with my XP420 and I suspect will work with all Epson printers. Thanks for tip.
tarafından
Works for my WF-2660. Many thanks! Thought it was heading for the rubbish!
tarafından
Thanks Alice Wins!! Driving me crazy
tarafından
22 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
I changed to print with border and now printer copies fine from panel.
I found the remedy from another website and it worked. Also it does not print a border .
Puan 22
14 Yorum:
I changed the borderless option to border and it worked. I found this tip online. Prior to this I had called Epson and the rep said I needed to pay $50 for s new driver.
tarafından
It worked for me too, but not from the glass platform.
tarafından
Thank you thank you. It was driving me potty! Solved now.
tarafından
Thanks , this worked for me also.
tarafından
Thank you so much. Worked on this for most of the day. Searched thru you tube and the epson manual to no avail. Can finally print again! Just have to buy some ink
tarafından
Yorum Ekle
Yes, same here. I went around and around through the settings, getting no where until I read this post. I changed the settings to "With Border/A4/Actual Size" and it copied. Only the bottom right edge of my copy shows a trace-about 1.5 cm, of a border that wasn't on the original. Ridiculous! Thankfully this was not anything that needed to be "perfect" in appearance. It isn't my machine so I don't have access to a manual, but you would thing making copies would be simpler!
-DocZ
Puan 5
3 Yorum:
This solved this problem. My base opinion of this machine after five days is it is a piece of crap - from inaccurate instructions in the manual to downloading drivers for Mac.
tarafından
I totally agree I hate this stupid printer Mac user also. I have court Monday have tons to print it was printing pretty good after I had to install the drivers AGAIN then all of a sudden all sorts of settings just changed on it's own 2 hrs later still not working. It's garbage!
tarafından
Awesome Who knew? You did!
tarafından
Yorum Ekle
This worked for me:
  • Home
  • Setup
  • Restore Default Setting
Puan 2
1 Yorum:
FINALLY!! Thank you so much
tarafından
Yorum Ekle
Also having this problem with Epson XP320. Found that "with border" was the only way to change setting to "plain paper," which was apparently my problem, as just changing to "with border" alone, would not do it. This problem occurred only recently, after a software update.
Puan 0
Yorum Ekle
Hi, I tried most of these suggestions, on my WF-2630 but none worked. It refused to copy, or let me change the paper source/size/type settings relating to copying! Then I went into Set Up/Printer Settings/ Paper Source Settings, and clicked down on A4/Letter Switching and found another option to switch paper size error reporting off! Changed that and everything working perfectly!
Puan 0
Yorum Ekle
I had an epson printer that you filled with ink
had it for 1 yr and had nothing but issues. It would not scan and ut would not set up as a wireless. It was a 350.00 piece of garbage. The first time I had to load with ink. ..the red ran into the black. I had extended warranty on it. However when it needed to be replaced, Epson kept 100.00 and sent me a check for 250.00. What the heck did I pay for a warranty for? I went back to my HP and have never looked back. I now have my wireless and scanner. I buy XL inks and have printed tons of paper. All for 150.00. What’s wrong with this picture?? Epson will never be in my household again!
Puan 0
1 Yorum:
none of these worked on my wf2750 which has copied fine for ages...
tarafından
Yorum Ekle
Copying Documents or Photos
Place your original document or photo on the product.
Load the paper you want to print on in the product.
Press the home button, if necessary.
Press the left or right arrow button, select Copy, and press the OK button.
Regards,
Will
Puan 0
Yorum Ekle
Yanıtını ekle
MICHAEL HINZ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 62
Son 30 gün: 249
Her zaman: 87,613
