Ana içeriğe geç
2008 yapımı netbook; Model ZG5 AOA150-1691; 8,5" ekran; 1,6 GHz N270 Intel Atom İşlemci
Motherboard problem, broken track.
Hi, my background is in electronics but found working on micro=electronis without circuit diagram difficult. Took this on as a favour for a friend. The DC socket was badly damaged such that the pin on the motherboard was so slack that I thought the track would be damaged. Sure enough I got a new DC socket fitted but still not charging up, there must be an open-circuit from the through-hole plating to the first component (probably pull-up resistor) the charging LED that emits when the Mains charger is fitted. Need to find out from circuit diagram or motherboard where the central pin is linked to. Can anyone help?
Update (01/26/2017)
Just realised my typing error! Should read BROKEN TRACK!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
I think that this is what you were asking after.
http://www.s-manuals.com/pdf/motherboard...
It is from this link.
http://www.s-manuals.com/notebook/acer_a...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hi Jayeff, the first web page didn't make much sense but certainly the second came up with required schematic. Will need a good magnifying glass now to identify the capacitor as my eyesight has deteriorated since working at component level on PCBs fifteen years ago. Thank you so much for your input and I will let you know how I get on ... Frank.
tarafından
Yorum Ekle
Yanıtını ekle
Frank Alexander sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 325
