Ana içeriğe geç
A stapler is a mechanical device that joins pages of paper or similar material by driving a thin metal staple through the sheets and folding the ends. Staplers are widely used in government, business, offices, work places, homes and schools.
Where does spring go?
where does spring go in manual stapler
Bu iyi bir soru mu?
Puan 2
2 Yorum
Where can I buy a spring for a nematic staple gun thanks Mary
tarafından
This doesn't work for swingline 444
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Eric Fields , I assume you are asking about the long thin feed/load spring which usually connects to a small tab on the staplers upper slide housing and to a tab on the slide. The links below should help you out in seeing spring mounting locations. On the guide link once you have opened it you can zoom in on where the spring is attached. Good luck.
https://www.youtube.com/watch?v=4micBJTd...
Stapler Maintenance
Bu yanıt yardımcı oldu mu?
Puan 8
Yorum Ekle
here we describe everything ..
https://dailytoolsguide.com/?s=how+to+fi...
Puan 0
Yorum Ekle
Yanıtını ekle
Eric Fields sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 72
Her zaman: 42,981
