Ana içeriğe geç
24 Temmuz 2014'te piyasaya sürülen Amazon Fire Phone, Amazon'un iOS, Android ve Windows Phone cihazlarıyla rekabet etmek için tasarlanmış ilk akıllı telefonudur.
Wifi signal weak after battery change
After replacing battery in amazon fire phone, I was unable to connect to wifi weak signal. it pick up signal only within 1 foot from router range. And also not full signal..
any suggestion what I did wrong during battery replacement process.
Bu iyi bir soru mu?
Puan 2
4 Yorum
This is just a guess after looking at the tear down on Ifixit. I would be looking at the flat antenna connections and making sure they didn't come loose. It looks like you could easily catch the antenna cable with the adhesive strip you pull out from under the battery.
tarafından
you are talkin about the black strip cable...
tarafından
I have this problem too. Can anyone solve it for me?
tarafından
I check all the strips also antenna cable which is perfect, not loose but facing same problem very weak signal of wifi and Bluetooth this all due to replacing my fire phone battery.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Here is a link to the Ifixit teardown for your phone.
In Step 7. of the teardown it mentions flat antenna cables, just after removing the battery. Perhaps you loosened their connections when you removed the battery.
Amazon Fire Phone Teardown
Hopefully this is of some help.
Update (02/03/2017)
Hi,
Here is an image showing the actual connectors. Check that they are both OK.
Resim
(Click on image to enlarge for better viewing)
Bu yanıt yardımcı oldu mu?
Puan 5
19 Yorum:
Haha. I was just commenting about the antenna cables. I must have clicked on the question just before you answered, and my screen hadn't refreshed.
tarafından
or the golden strip you are talking about
tarafından
Hi, It may be both as it mentions cables (more than one)
tarafından
I checked it all the way.. black strip and golden strip are tightly inserted...
tarafından
again tighten the black trip...but no success. wifi signal bar some time flicker..and jump to full signal but all sudden drop.
tarafından
14 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Khurram Shahzad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 3,616
