Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 Soru Tümünü görüntüle
Weird Issue on startup
Hi Guys.
OK i have to say i have never seen anything like this before at startup.
It was doing this when it came into me & i did DFU reset which seemed to resolve the issue but after a couple of days (when the client came to collect it typically) it started doing it again.
the first part of the vid is in real time then i used same clip but slowed it right down.
Anyone seen this before or have any idea?
Thank is advance
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I haven't seen this before...usually I see the Apple logo bootloop.
That said, it does appear as though the boot process is interrupted pretty early on. There may (and I say may) be a logic board issue that is causing this failure. What I find odd is that you say it worked well for a few days after a DFU.
Is it recognized by iTunes or is it completely shutting down?
If iTunes sees the iPad it may be a LCD/Backlight issue. If not, then it could be another subsection that is pulling things down. If you have access to schematics and a multimeter, I would probe some power rails and visually inspect the logic board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Kenny Leonard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 85
