Ana içeriğe geç
The Canon Pixma MP480 is an all-in-one color inkjet photo printer released in 2008.
21 Soru Tümünü görüntüle
How to reset page counter for ink absorber full (error 5B00)?
I have been trying everything I can find on google and youtube (short of downloading a sketchy exe file), but I can't reset the page counter. I already cleaned out the ink absorber pads, but my printer won't print until this has been reset. I hate planned obsolescence.
Bu iyi bir soru mu?
Puan 65
19 Yorum
i have a 5B00 error and let me know how to approach it
tarafından
Last week I had a similar іѕѕuе, I couldn’t reset the page counter on my Canon Pixma printer.
I tried everything and nothing helped.
Finally I managed tо fix this error after getting help from Cannon Windows Support
Follow the steps here: http://bit.ly/Error5B00
It should solve the issue
Goodluck
tarafından
There are various reset methods for different Canon printers. None allow resetting of the 'ink pad full' on the MG2550S, thought you may get limited access to other features like 'nozzle check'. Even physically transfering the eeprom to an eeprom reader/writer doesn't help unless you know what parameters to change.
tarafından
Please follow https://www.youtube.com/watch?v=Zu_vONAE.... hope this helps everyone
tarafından
hie guys, i have got canon TS5040 , it is reflecting error 5b00 wat can i do,,
tarafından
14 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Have you tried the following:
1. Press and hold the power button
2. Whilst holding the power button operated, plug the power cord back into the printer.
3. Keep holding the power button until the printer begins to reset itself and come online, then release the button.
4. Wait for the green power light to turn off, then press and release the power button again.
It should blink for 2-3 seconds and then stay on.
Hopefully the printer has been reset and is ready to print again.
Bu yanıt yardımcı oldu mu?
Puan 22
14 Yorum:
No, this didn't work. When I plug in the printer while holding the power button, the green light comes on, but nothing else happens. When I release the power button, the light goes off again and the printer does not come on without having reset anything.
tarafından
Hi, @lynanne ,
Just for my information, did you also try the procedure as shown in the link?
tarafından
this didn't work for me either and the link doesnt work
tarafından
Hi, please suggest an answer for my Canon e470
tarafından
These are throw away printers. Remember that. Once that ink absorber error comes up thats it. Time for the dumpster.
tarafından
9 tane daha yorum göster
Yorum Ekle
I had the same issue and solved it this way.
  1. Press and hold the power button (While connected to power)
  2. Press the ‘cancel’ button SIX (6) TIMES
  3. Release all buttons
  4. Press ‘cancel’ button FIVE (5) Times
  5. Press the POWER button ONCE. (It should print a reset information page)
  6. Press the power button to turn off the printer then turn on again.
  7. This worked for me.
Puan 17
16 Yorum:
Hi Simion,
Could you please help me to reset Canon Pixma G4000 printer. I've tried your guidelines but nothing happened.
tarafından
thanks a lot
tarafından
its worked with me but different first step
power off the printer
hold cancel first then hold power , then release cancel and keep on power then press 6 times on cancel
Release all buttons
canon G3400
tarafından
This has worked out marvelously, i was so worried about taking back my Canon Pixma G3411 back to the vendor but was able to sort out the issue locally using this guide. Thank you for the help Sir
tarafından
Dear Sir,
Could you please help me to reset Canon Pixma G2400 printer. I have tried your guidelines but nothing happened.
tarafından
11 tane daha yorum göster
Yorum Ekle
My Canon G2000 printer has a 5b00 error and I have found this software, it fixed the 5B00 error on my printer, advise you to try it out - http://resetkey.net/reset-canon-g2000-co...
First: You have to put printer into SERVICE MODE
  • Turn off Canon G2000 printer
  • Press and hold Canon G2000 printer’s RESET button
  • Press and hold printer’s POWER button.
  • Released Canon G2000 printer’s RESET button, POWER still pressed
  • Press and released Canon G2000 printer’s RESET button 5 times
  • Released Canon G2000 printer’s POWER button:
  • Now, Canon G2000 printer on SERVICE MODE condition. In this condition, computer detect found new hardware.
  • When operating system detect FOUND NEW HARDWARE, wait about 20 seconds and press CANCEL
Second: Download Wicreset or iWic to reset Canon G2000 waste ink counter.
Puan 16
5 Yorum:
Please give a solution of this problem for Canon e470.
tarafından
Thank you very much! Reset my Canon 3000 in a minute. Easy. Had looked around at buying a new printer but really had no time for that anyway, i try your link and It works
tarafından
Thank you pro, it works!
tarafından
Hi I need Help My Canon G4100 came with 5B00 issue now with this Lockdown no where to take it to fix Pls HELP Tks
tarafından
Great help, thank you very much!
tarafından
Yorum Ekle
hi you can try the service tool here….
https://truee2.blogspot.com/2020/05/how-...
Puan 1
3 Yorum:
Indeed, this solution worked flawlessly. Thanks a lot!
tarafından
You do not even need the tool on some models. See, for example: https://www.youtube.com/watch?v=Zu_vONAE...
tarafından
This worked amazingly for me as well. I couldn't get it to reset the manual way no matter how hard I tried. Using this software, I was able to fix the problem in 5 minutes.
tarafından
Yorum Ekle
It means its time for a new printer. Dont waste your time trying to reset the ink absorb counter. It wont work.
Puan 0
3 Yorum:
The trick mentioned just before yours work. There is nothing constructive about telling to change a printer that can be easily fixed...
tarafından
Catherine Desrochers speaks the truth. Here, for example, is how to reset the counter on a G3200: https://www.youtube.com/watch?v=Zu_vONAE...
tarafından
You can’t reset this code. It means it time to buy a new printer. I wouldn’t lie to you. Its almost impossible to re-set the ink absorber counter.
tarafından
Yorum Ekle
Hi could you plz help me my printer is canon Ts6120 code error 5B00
Puan 0
1 Yorum:
Its almost impossible to re-set the ink absorber counter. It means its time to buy a new printer. Trust me on this.
tarafından
Yorum Ekle
Yanıtını ekle
LynAnne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 44
Son 7 gün: 261
Son 30 gün: 1,109
Her zaman: 264,434
