Lenovo A6000 feeble sound at the receivers phone
the sound at the receiving end is vey feeble.what is the remedy?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Try using the earphones with the microphone attachment and make or receive a call.
If you still cannot be heard properly then there is a problem with the voice transmission circuit in the phone.
If you can now be heard properly then there is a problem with the phone's microphone. It may be faulty or the voice "inlet hole" on the bottom of the phone may have become blocked with lint etc.
To check the last possibility, use a strong light and a magnifying glass to see if the hole appears blocked. If it does DO NOT try and clear it using a pin or probe as the microphone is directly behind it and you may damage it. Try a vacuum cleaner using short sharp bursts to see if this clears the obstruction.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 218
