Ana içeriğe geç
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
iPod Won't Turn on
My son has an iPod and it recently stopped accepting a charge. I've taken apart many devices before but wasn't sure where to start with figuring out what is wrong with this one. I figured taking it apart and putting it back together would be a good start (especially since he is a young kid and has likely dropped it a few times). Any suggestions or guides for how to diagnose?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Replacing the battery would be a good first step however it does require soldering. There is no specific guide to replacing the battery but you can use this one nonetheless.
If the battery doesn't solve the problem, then you likely have a defective charging circuit on the logic board. This can be caused by using non-genuine chargers.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
I think this will likely be the next step I take, thank you for your help and I will let you know if it works.
tarafından
Yorum Ekle
Does the charging port cable plug in fully without gap?
If not clean out blockage inside port with toothpick or equivilant.
Make sure to avoid touching the 5 charging pins in the port. They can only be pushed down and not pushed to the side.
Puan 3
1 Yorum:
Sorry for taking so long to get back. Unfortunately that didn't help. Thank you though!
tarafından
Yorum Ekle
Yanıtını ekle
armytrixter85 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 253
