Ana içeriğe geç
Repair guides and troubleshooting for the Acer Aspire 5750. This is a 2012 Aspire budget laptop aimed at the casual household user or for small business use.
26 Soru Tümünü görüntüle
Acer aspire 5750-6842 - Windows failed to start
It says for me to contact the system administrator or computer manufacturer for help file / Windows system32 config system status 0 xc000021a system restarting file is missing or corrupt
Bu iyi bir soru mu?
Puan 0
1 Yorum
Windows 7, 8.1, or 10?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Try staring the laptop in 'safe mode' and selecting the option as outlined below.
Here is the procedure:
Restart the computer
Wait for the computer to complete the POST process (Acer appearing on your screen)
Quickly press the F8 key repeatedly until you see a list of boot options available. (Between the Acer screen and the Windows starting screen. If you start too early the laptop will beep, just release the F8 key for a few seconds and start tapping it again. If you are to late and the starting Windows screen appears shutdown the laptop by holding the power button until it shuts down and then start again. It is all the the timing you only have a small window of opportunity to access the advanced startup options menu. That is why you should tap F8 very quickly
Choose Last Known Good Configuration (your most recent settings that worked)
Press Enter
Wait for your computer to boot into this mode all the way to the Windows desktop.
Once it is there, wait for the HDD activity to settle down a bit, (the HDD light should stop being on continuously) and then shutdown the laptop in the normal manner from the desktop.
Once the laptop has shutdown completely restart the laptop and see if it starts normally.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Gertha Urrutia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 1,552
