Ana içeriğe geç
The Motorola Droid Ultra XT1080 is an Android (4.2.2 Jelly Bean) smartphone with 1.7Ghz Dual-Core median processor. It was released 23 July 2013. This device is also very similar to the Droid MAXX.
11 Soru Tümünü görüntüle
Are the display and glass fused as one unit?
Hi, my friend is giving me a droid ultra but it is cracked and i might want to replace it in the future. i have one question though are the display and glass fused as one unit or are the seperate? it would be nice to only replace the glass cause the touch buttons at the bottom only the back button works. the home and multitask buttons dont work at all anymore.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@dudefoxlive, Keitaro, Yes, the glass can be separated from the LCD, see video link's below on how it is done and link to replacement glass which you can also do a search on for better pricing. Good luck.
https://www.youtube.com/watch?v=X5LBMH_y...
https://www.youtube.com/watch?v=yn8xvhFO...
https://www.amazon.com/Replacement-Part-...
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
sadly at the moment i can not view the video due to filtering on my school wifi. i plan to replace the screen at some point in time but not right now. for the time i am going to use an app for the home and mutlitask button replacement.
tarafından
well after looking at the videos turns out the glass is glued to the lcd which is not something that i am very comfortable trying to remove. it would be easier for me to just purchase the whole assembly as one unit LCD and digitize already glued together as it would be much easier for me. plus the screen has LCD burn cause the previous owner never locked the phone when he was not using it so it was always at the home screen and it got burned into the LCD.
tarafından
@dudefoxlive, Keitaro, Yes, much simpler repair to replace the assy., thanks for posting back. Good luck with your device.
tarafından
@lpfaff1 i will say this if you do it be careful when putting the board back into the housing. i broke the volume buttons and they need to be replaced. if only i can fine the part somehow.
tarafından
@dudefoxlive,Keitaro, Best to just try a search using your make and model# for required replacement part. I will post a link below, it may be the part you need.
https://www.mobilesentrix.com/motorola-d...
tarafından
Yorum Ekle
Yanıtını ekle
Dudefoxlive sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 135
