How do I replace the battery
My visual land 10 prestige pro will not charge with the computer or the charger. I assume the battery needs replacing. How do I do that
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@grannold5,Jackie, It could be a faulty battery, but there are other things to try first before spending money on a battery. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, A lot of forums feel a factory reset can fix this type of issue link#1 will take you through some steps if you would like to try(note all data will be lost doing a factory reset), Reset did not work, either the cable or charge port may be damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue and straighter any bent terminals with a tooth pick carefully. (loose charge port seem to be an issue with this device).
If port damaged/loose it will have to be repaired/replaced. If port looks/test good the battery or connection is probably bad. If port is found to be bad, this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link #2 to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board(not your device) just showing how it is done.. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.tabletroms.com/forums/prestig...
Visual Land Prestige 10 Motherboard Replacement
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,064
