Ana içeriğe geç
Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
Will not turn on
The printer was working a few hours ago and then turned off. I have checked the power supply and cord to the printer and these are fine. The printer did come back on for about 45 seconds, after I removed the power cord and waited for a few minutes. However after that one time, it has not come back on even doing what was first tried. Is there a fuse on reset button inside? Thank you
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thank you! It is working again.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
HP's suggestion is to turn the printer off for a half hour and turn it on. If it is still having problems then contact HP tech support. If this is still in warranty they may replace it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dale Devenport sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 2,969
