Ana içeriğe geç
The BlackBerry Passport SQW100-1 is a phone that has a physical keyboard and a touchscreen feature in one. Its square-like shape sets the BlackBerry Passport SQW100-1 apart from the other BlackBerry phones.
How do I get past the Finalizing Device Setup screen?
I turned my passport off the other day to avoid it ringing during a movie. Since I turned it back on two days ago, it has been in a loop where I get the 'Finalizing device setup' screen. It get to 100% and then restarts the whole thing over again. Have tried soft start from the power button, soft start from the volume toggle keys and most recently have removed and reinstalled the battery. Each re-set starts the pattern all over again. Help :-)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try removing the SD memory card. Then restart the device.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I have the same issue...uhg!
Puan 0
Yorum Ekle
I had this problem twice with my Passport. The only solution I’ve found is to re-install BB10 OS and it worked. Via BB Link, I downloaded BB 10 on my PC and could install it. Caution : BB Link cannot be installed on Windows 10, and you must know that you will loose all your data if you do so.
(excuse my bad english, I’m french)
Puan 0
Yorum Ekle
Yanıtını ekle
Julie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 6,862
