Ana içeriğe geç
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 Soru Tümünü görüntüle
My screen is darker than normal.
My tv is about 3-4 years old. What is causing the picture to go dark. I've checked the brightness and have reset everything. Still not bright.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 22
5 Yorum
my screen is dimmer on the bottom half
tarafından
My screen keeps flashing & really dark on right side. Had this TV for 3-4 years.
tarafından
I have a 5 year old Vizio P652UI-B2 and the top 1/3 of the screen is much darker than the rest of the display. I've got the backlighting as high as it will go and I can barely see white text near the top of the screen.
tarafından
my tv has grown darker over the last few weeks, Any ideas what I can do to fix this problem.
tarafından
Mine is doing the same thing! It started in the right top corner and worked its way across the tv. Now the bottom left corner is the only part still normal. I’ve tried resetting it and messing with the picture setting with no luck. it’s about 5 years old.
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The most cause for dark screen is defective Led’s inside the panel Some of the leds are failing and causing the screen to look dark on one side or entirely. You will need to replace the led strips in the panel to resolve the issue. Shopjimmy.com has a lot of backlight stripes for purchase, This is a major repair and will take time and patience to replace them. They also have a video on how to replace Backlight strips. Also check the V+ And V- voltages going to the panels leds
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
@deek72 could be a bad panel, bad power board/inverter or bad LED backlight array. It will depend on how dark it gets. Post some images of what you see with your question. Use this guide for that. Remove the back of your TV after you unplug it and take some pistures of the boards on the inside of your TV as well. Let us know what the model is.
Puan 3
1 Yorum:
Should not have to troubleshoot a TV that is so new. Like most of us don't have that much time. Or skill. ha
tarafından
Yorum Ekle
tv was $700 is it worth fixing ?
Puan 1
1 Yorum:
@al marinucci depends what it all looks like. If it is a backlight issue or a power board than yes, it would make economical sense to fix it. If it is the panel, most likely not. Let us know the exact make and model for your TV and try to describe what it all looks like.
tarafından
Yorum Ekle
Click on menu than pictures top bar Standard picture
Puan 0
Yorum Ekle
I have a tcl roku tv that just went dark. But when you try to turn it off there is a little bit brightness but not too much. I made my way around to the brightness and it didn’t do a thing. It powers on and off okay. Do you think it’s the led? Is it worth to fix it?
Puan 0
Yorum Ekle
The issue is most likely the back lights to the tv have blown
If that doesn’t fix it then it is a motherboard problem
Puan 0
1 Yorum:
I've replaced all the leds, all 4 boards and it still is an issue. The only thing I haven't replaced is the wifi module. What else could it be? Turns on. Is a bit brighter in HDR but overall can't be watched during the day.
tarafından
Yorum Ekle
Yanıtını ekle
Eric sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 151
Son 30 gün: 730
Her zaman: 74,540
