Help with my speedo 350gd
Can anyone help me identify the connections in the back of the speedometer its for 350gd part #4635420206
Thank you .
Bu iyi bir soru mu?
Thank you .
Bu iyi bir soru mu?
http://www.iauto.lt/mercedes-benz/Cross-...
Look at find numbers 17, 233 and 236.
Bu yanıt yardımcı oldu mu?
Thanks for reply i have visited that web site . The problem that the speedo is old and i couldn't find the parts i could find the speedo without its harness so i decided to add a universal pulse generator and connect it to that speedo but i am not sure where to connect the wires .
Sorry, I am unable to find a pin out for the connectors. Since the link I gave has connector part numbers, you should be able to make a custom adapter cable. Though, given there appears to be 5 pins, there are 120 possible combinations (24 combinations if 4 pins, hard to tell from the photo). It will take some time for trial and error, but you'll get there. Sounds like a fun project you have.
@lpfaff1 , if you look again, you'll see that find number 14 has three part numbers associated with it: 106, 206, and 306. The difference being the 106 and 306 are in miles, while the 206 is in kilometers.
When I first saw the link, I initially thought the same as you, but then I saw the multiple parts numbers.
Yeah . Actually my car is 1992 300ge and it use mechanical speedo after many problems i decided to replace it with electric one . Finding the speedo was easy but the wiring harness and the connection to the transmission was the problem. I already ordered pulse generator and prepared the whole wiring and will start testing the speedo tomorrow as the pulse generator will arrive tomorrow from summitracing.com .
@ender123 just for completion sake, do you know what year 350 GD the speedo is out of?
@ender123, Ender , Can not identify connector, but if you are looking for replacement part try a large local auto dismantler/car salvage yard and even if they do not have the part on hand, most are linked through a computer system to 100's of other auto wrecking yards and can locate the part for you. Good luck.
Thanks ... this is new speedometer but the car model is old so no one could help nor they could provide me with connection diagram. I will wait for other answers if i couldn't find an answer i will start the trial and error process...
Ender, Sure thing, good luck with your project, thanks for replying back, one of the other ifixit volunteer's may be able to help.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 210
1 Yorum
@ender123 ambitious project you have chosen. what year is your 350GD and what year is the speedo from?
oldturkey03 tarafından
