Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
How to fix the Fan header
I was disassembling my ps4 and got down to the fan header. I thought that you had to pull the cord horizontally and did that without knowing that I had to do it vertically. So then I accidentally broke the fan header but was able to repair it, temporarily, with the ps4 shutting down most of the time due to overheating. I want to know if there is a permanent solution to fix the fan header, so then I don't have to play with it all the time to keep the fan running.
Bu iyi bir soru mu?
Puan 3
2 Yorum
Can you post pics
tarafından
this will help with posting a picture
Adding images to an existing question
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds like you must be talking about the fan connector on the motherboard. If that's the case then you have several options:
1) Solder the fan wires directly to the correct pins on the motherboard
2) Replace the connector...if the connector on the motherboard itself is broken then you would have to probably get a connector from a junk motherboard. If it's the connector on the fan side you could just replace the fan.
3) You could purchase a new motherboard...this option is obviously not the best since it's so expensive but it is an option.
I hope this helps. Good luck!
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hey Steve, I have been trying to buy a new set of fan headers (10 pieces) from Ali Express but they sent the plugs from the fan side NOT the sockets I thought I ordered, now they have blacklisted me from buying anything because I returned the wrong items! Where do you suggest I can source the correct item(s) as I am in Australia and it is hard to get parts for consoles? Looking forward to help.
tarafından
Yorum Ekle
This happened to me but it was on the fan side. I just discarded the plastic and connected the cables directly to the mother board without having to solder. PS4 1100 series
Puan 0
1 Yorum:
How did you manage to do this?
tarafından
Yorum Ekle
I did it with a needle it lifted it and slides out after
Puan 0
Yorum Ekle
Yanıtını ekle
Astrowings230 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 6,124
