How replace power button
please help how i can repair button phone dont turn on
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Bu yanıt yardımcı oldu mu?
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 4,268
2 Yorum
I need help to find where to get a new power bottom for Asus Zenfone 2
David tarafından Paylaş
You can get it on Aliexpress.
annmarie ward tarafından Paylaş
