Ana içeriğe geç
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
How replace power button
please help how i can repair button phone dont turn on
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
I need help to find where to get a new power bottom for Asus Zenfone 2
tarafından
You can get it on Aliexpress.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Asus ZenFone 2 Motherboard Replacement
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Puan -1
1 Yorum:
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
tarafından
Yorum Ekle
Yanıtını ekle
Anton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,975
