undetectible Intermittent Starting Problem
Info on the problem.
- 2008 Ford Focus 1.6 Style
- Auto
- 30,000 Miles
Short version of what’s wrong with the car and important notes:
- Mostly heat related starting problem
- The car drives perfectly
- There is no injector pulse when fault is occurring, the most important info here is wiggling the wiring harness WILL get the car to start when the car is NOT hot, however when the engine has warmed to normal operating temp wiggling wires will not have any affect which I’m guessing is due to thermal expansion.
- ECU has been swapped out with another new one and problem persisted.
- Disconnecting the ECT sensor will get the car to start almost 99% reliably.
- ECT sensor has been replaced.
- Crank sensor has been replaced.
- No fault codes ever registered.
I have been trying to trace the problem through the wiring harness but it’s proven to be too difficult.
The current process I’m using to find the problem is to investigate all sensors and their circuits that have anything to do with fuel injection, the only problem is that I do not have a large knowledge base when it comes to cars.
I am wondering if you guys can help me and please be so kind to tell me what sensors you know to affect fuel injection and if you’ve ever heard of such a problem before or know of anything that could help.
I have a scanning tool and have been inspecting how certain sensors work and everything seems to be fine (voltages .etc) to my knowledge which again isn’t vast.
I have had a friend bridge the whole ECT sensor circuit to eliminate it and sure enough the problem is not regarding the ECT circuit.
I’m getting close to having to give up a perfectly good car all because of some stupid wiring problem.
Thank you for any help, it is much appreciated.
Update (03/16/2017)
One other thing I'd like to mention even though it isn't that major is that with the ECT sensor being disconnected the car is still not starting a lot more now, seems like the problem is getting worse which is a good thing in regards to having a chance at finding it!
Update (03/16/2017)
Update:
Throttle position sensor changed to no avail.
further testing revealed that the wires around the fuse box had a significant effect on the problem.
I think from my testing it's safe to say the issue is within the wiring inside the fuse box.
The only wire I can think of that could cut off injectors would be the injector relay circuit.
Is this correct to think this?
Further more I'm having trouble locating the injector relay since the owners manual is useless at defining which fuse/relay is where.
Is there any obvious signs to look for when trying to find injector relay?
thanks for your help!
Bu iyi bir soru mu?
7 Yorum
dom, could not find much, try the link may help. Sorry you are still having issues.
ftp://ftp.idm.ru/pub/ffclub/2003_5_Focus...
L Pfaff tarafından Paylaş
Pull ignotiom out wrap with electral tape problem solved
dustyanders tarafından Paylaş
Fuel pump relay
Jimmy Fend tarafından Paylaş
I have this problem too . Intermittent starting problems and have had it to many garages who charge me for looking at it but can’t fix it due to the problem not occurring whilst it’s there . It can go for weeks without a problem then suddenly not start and leaves me stranded in places . I once called the RAC and it started 2 hours later (before they’d had a chance to look at it ) . It’s so frustrating. I wondered did you get to the bottom of your issue ?
Andrea tarafından Paylaş
Duel mass fly wheel, if fitted, the crank sensor, can't read it grooves, the signal fazes on and out, there for bad starting will occure
Neil Harrison tarafından Paylaş
2 tane daha yorum göster
