SRS light on dash borad
What dose the SRS light on the dash board means?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
@sandlak2e ,SRS light on the dash board means, if light is staying on there is a fault detected in the supplemental restraint system/safety restraint system(usually has to do with a fault in air bag system). There will be a code to be read from the computer to enable telling which part/circuit is having an issue. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. If you would just like to reset the light see the link below, if the light returns I recommend you have it addressed for your safety.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Bu yanıt yardımcı oldu mu?
It also could mean the sensor in the seat belt us faulty
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 94
Her zaman: 26,828
