Ana içeriğe geç
W123 şasi; 1977 ile 1985 model yılları arasındaki Mercedes coupe, sedan ve station wagon modellerinin 240D, 300D, 300TD, 280E ve diğer çeşitli modellerini kapsar.
fuel gauge erratic behavior
Occasionally my fuel gauge jumps left to right and right to left, then resets to correct position.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@lollygirl, David , Check the wiring/plug by the tank to see if loose/dirty/corroded and if able to check ground wire and loosen and retighten to make good connection, if all looks good the in tank fuel sending unit may be faulty or a bad actuator at the fuel gauge on your dash. . See links below for more info and trouble shooting ideas. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://mercedessource.com/problems/elec...
http://www.benzworld.org/forums/w126-s-s...
Mercedes W123 Yakıt Şamandırası Değişimi
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
How would I know if my fuel gauge actuator is bad? I noticed that the needle was moving as I moved my sending unit float back and forth.
tarafından
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 25
All Time: 4,009
