Ana içeriğe geç
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Soru Tümünü görüntüle
losing water out of back engine
losing out of back engine
Bu iyi bir soru mu?
Puan -1
1 Yorum
where in the back is it leaking? Within the bellhousing, above it or the sides of the engine toward the back? How much water is leaking out, how often do you have to replace the fluid? Need a little bit more info to give you a better answer since there are plenty of opportunities for leakage. Thanks
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have your freeze plugs checked. If the engine has frozen with insufficient anti-freeze there are plugs built into the engine that will pop out to avoid damage to the block.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
It could also be leaking from the connections to the vehicle's heater core.
Puan 2
Yorum Ekle
I was a Chevy tech for 20 yrs...couple of areas to look.
There could be a connector at the rear of the intake manifold that connects a metal pipe from the manifold to the heater core. Those get corroded over time and can leak.
Also the intake manifold gaskets themselves can leak in that area too.
You can rent a coolant pressure tester from the parts store and pressurize the system to locate the leak.
Hope this helps
Puan 1
Yorum Ekle
thanks. the heater core leakage is probably the answer. My heater is working only on and off. Thanks
Puan 0
Yorum Ekle
If it is leaking out of the back of the engine, it is probably the freeze-out plugs as mayer stated...low coolant will cause the heater to work intermittently or not at all. Check closer before you get the heater core replaced.
Puan 0
Yorum Ekle
Yanıtını ekle
john sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 939
