No video capture devices were found
Tried FaceTime,photo booth, still no connected camera is the reply.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Go under the Apple to about this Mac > System report > Hardware > Camera and see if it sees one. Let us know your results.
Bu yanıt yardımcı oldu mu?
It doesn't see any. "No video capture devices were found."
Please help me too. My system report says No video capture devices were found.
Here it is January of 2022 and I am having this same issue after a software update, and Apple can’t figure out what is going on. None of the troubleshooting has worked. They can’t find anything wrong with the actual camera and they refuse to look into the actual software. Has there been any fix to this solution in the past for anyone that troubleshooting did not work for?
As you were the most recent poster I shall pester you! It's not a little over a year later. Did you ever get this solved? I'm trying to get this sorted on a Mac Mini and know exactly how frustrated you must have been.
Mac mini has a camera??????
@croupier - No built-in camera but a external Web camera might be Nicks issue.
That gets down to the cameras drivers for the systems running macOS. One can’t just expect any Web cam to work.
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 22,820
5 Yorum
The camera is right now working well since I disconnected it and then connected again.
alfredoe.contreras tarafından
RESET A MACBOOK SMC
If you have a MacBook computer, here is how you go about resetting your SMC.
Start by shutting down your MacBook
Ensure your MacBook's power adapter is attached to the computer.
On the MacBook's keyboard, hold down Shift+Control+Options keys simultaneously, then turn the power on to start the computer.
After powering on the machine, keep the Shift, Control, and Option keys all held down at the same time.
Allow thirty-seconds to pass before releasing the keys, allowing the Mac to boot as normal.
Once your computer starts up, check to see if you now have access to your camera.
eldarnir tarafından
You're welcome !
eldarnir tarafından
Have you tried to reset the NVRAM? Hold Command-Option-P-R at boot and wait for three boot chimes. Has this MBP been opened lately?
Justin Berman tarafından
What is the solution?
gerald tarafından
