Ana içeriğe geç
Honda Fury, büyük bir motosiklet üreticisi olan Honda'nın ilk seri üretim chopper modelidir. Chopper, tüm özel stil türleri arasında en uç noktada kabul edilen ve daha uzun ön çatallar ile radikal şekilde değiştirilmiş gidon açıları sayesinde uzatılmış bir görünüme sahip özel bir motosiklet türüdür.
Bike missing and dying
Was riding on the Highway when all of a sudden my bike started missing and jerking. Check engine light flashed and it died. Started slowly and ran for about 2 minutes and started missing and died again. What might be the cause?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Connie Toole, Could be fuel issue, bad fuel,filter plugged,pump bad if equipped, gas cap vent hole plugged, etc. or could be ignition/charging system related, fouled plugs/bad wire/ground, faulty coil, weak battery, etc.. Since the engine light did come on there should be an error code that may lead to the issue. Have the computer scanned for codes. Not sure if they can do bikes, but may be worth a shot as some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. If they can not retrieve the codes then you will have to pop into a good local bike shop that can. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Stating problem
tarafından Paylaş
Yorum Ekle
Stating problems
Puan 0
Yorum Ekle
Yanıtını ekle
Connie Toole sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 2,053
