Ana içeriğe geç
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Soru Tümünü görüntüle
Right LCD Screen Assembly hinge lock broken after drop
Well, i just dropped my MacBook Pro 13" Mid-2012 and the right hinge broke, but not the movable part but the hinge on the screen assembly
Is there any way this can be fixed?
Image included.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The part you highlighted is attached to a large frame thing inside the display assembly. You can access and replace this frame, but you will have to remove the glass and the LCD panel first, which is quite a time consuming repair (MacBook Pro 13" Unibody Mid 2010 LCD Replacement). Then, you can take out the screws that hold the frame in place, heat the adhesive and the frame will separate from the back cover. I don't know of any sources that sell just the frame, so you will probably have to salvage it from another LCD assembly.
It's most likely the best for you to just buy a whole display assembly and replace the broken one with it. (MacBook Pro 13" Unibody Mid 2012 Display Replacement)
MacBook Pro 13" Unibody Mid 2010 LCD Görseli
Kılavuz
Zorluk:
Çok zor
2 - 3 hours
MacBook Pro 13" Unibody Mid 2012 Display Görseli
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Robert G sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 142
