Ana içeriğe geç
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
20 Soru Tümünü görüntüle
starter solenoid wiring diagram from battery to solenoid
Craftsman Riding Mower model27011 i need to know how the wiring diagram from battery to solenoid to starter is configured
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 11
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@lawnboy707 verify your complete model number for us. This diagram should work for your mower.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
I want to know to
tarafından
@randystarcher you would like to know what :-)? Have you checked the above posted diagram?
tarafından
Yorum Ekle
here is the wiring diagram i found at https://www.searspartsdirect.com/model-n...
Puan 2
2 Yorum:
In the diagram there are the numbers "1-26". It would be helpful to have the key along with the diagram to help identify what each number correlates to. I.E. number 3 identifies the anchor bolt for the hot wire to the positive battery terminal
tarafından
@Michael Dodson
If you click on the link provided in the answer above your comment you will get the Sears webpage where it came from.
Under the diagram on the page is a list of the part numbers as shown in the diagram and if you then click on the relevant part i.e. part #1 = Sensor 91031 you will get the part description etc.
Search online using the required part number to find suppliers that suit you best e.g. this supplier is cheaper than Sears (although shipping may be a factor to be aware of depending on your location)
tarafından
Yorum Ekle
@lawnboy707, John, Below you will find the manual and pic's/schematic of how wire's are hooked for starting system, for Model #502270111 CRAFTSMAN Lawn, Riding Mower Rear Engine. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.searspartsdirect.com/model-nu...
Puan 1
Yorum Ekle
Yanıtını ekle
john sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 92
Son 30 gün: 229
Her zaman: 86,062
