Ana içeriğe geç
Ev kahve ve espresso makineleri için bilgilendirici kılavuzlar.
forever blinking in 3 fast 1 pause sequence
Hello!
my Krups Nespresso Inissia XN 100 machine after heating up keeps blinking with the following sequence: 3 fast 1 pause. The assistance said that there is an error in the electronics. Any suggestions rather than getting rid it of my poor Nespresso?
Bu iyi bir soru mu?
Puan 1
4 Yorum
Just spoke with Nespresso customer service: "The Essenza Mini will NOT work with an inverter." Oh well, back to the store... :(
tarafından
1. Switch off at wall.
2. Turn on at wall.
3. Hold in the lungo(large cup) in for 5 seconds.
4. Wait for device to heat up.
5. If the lights do not flash then congratulations!
6. Enjoy coffee.
tarafından
Genius! It worked.. the relief!
tarafından
Francis, it didn't work on my DeLonghi inissia Nespresso, any idea how could I force its PCB to a hard reset?
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
@leoborni see if it is stuck in descale mode. Press both green lights for 3 secs and it should flashing at a slower rate. When they stop flashing it should be good to go.
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
Hello!
I checked and it is not in rescaling mode unfortunately.. the blinking sequence is different. I tried many time to press both bottons in different combinations of time and nothing happens :(
tarafından
Okay lets see is we can find out more about your Krups.
tarafından
What extra info can I give you? I'm desperate for an espresso in the morning T.T
tarafından
trying to find a schematic to see what we can check
tarafından
do I have to find a schematic? or are you..? sorry.. my English is what it is xD
tarafından
2 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
I’m my case it was the water container had leaked water into the hole underneath, I had descaled using vinegar then done all the cleaning and flushing only for it to start flashing continuously. I removed the water container dried it out and now all fine again, coffee back. It was in the hole not in the round gully that the container sits in. It worked for me hope it works for you.
Puan 5
1 Yorum:
What's happening if you press one button both flashing, and if you press both still doing the same
tarafından
Yorum Ekle
Just wanna ask, have any of you found the solution?
Puan 0
Yorum Ekle
In my case, (after speaking with support) I was told the coffee maker doe not work with power from an inverter, like in a motor home.
Oh well. Returned it.
Puan 0
Yorum Ekle
I just had the same problem, both lights would keep flashing 3 times. Tried pressing them both, pressing one,….
Nothing would work. Switched it off at the wall, waited 5 seconds and switched it back on…
Works perfectly now
Puan 0
1 Yorum:
this worked temporarily, after a few days it failed again until permanently
tarafından
Yorum Ekle
In my case, after reading here, I removed the water container dried the hole put container back and turned it on and it worked fine.
Puan 0
3 Yorum:
Also mine is a Krups Essenza Mini. And not Inissia.
tarafından
Unplug your Essenza mini, then plug back in and press/hold lungo (Big cup) button for 5-7 seconds, the espresso (small cup) button will flash very fast 3 times, you have reset your machine and you are good to go. I just did it right now on a customer's machine after trying other solutions.
tarafından
@furqanshafi Unplug your Essenza mini, then plug back in and press/hold lungo (Big cup) button for 5-7 seconds, the espresso (small cup) button will flash very fast 3 times, you have reset your machine and you are good to go. I just did it right now on a customer's machine after trying other solutions.
tarafından
Yorum Ekle
Yanıtını ekle
Leo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 55
Son 30 gün: 296
Her zaman: 95,532
