Kondansatör değişimi
36 Cevap 262 Puan |
My Keurig makes brewing noises but doesn't brew. |
37 Cevap 11 Puan |
Why is my Keurig Classic constantly turning off while brewing? |
19 Cevap 46 Puan |
Light blinking two times, pause, two times, etc. |
8 Cevap 17 Puan |
My Keurig Will not draw water |
Belgeler
Parçalar
- Delonghi Water Tank - AS13200250
- Delonghi Rubber Cleandisk (Black) - AS00001634
- Delonghi Filter 1-Dose Coffee with Rib - AS00002564
- Delonghi Glass Carafe - HZ1029
- Delonghi Water Tank - AS13200251
- Delonghi Carbon Filter - 7313285779
- Delonghi Infuser Diffuser Kit - 7313251451
- Delonghi Infusion Kit with Black Push Button - 7313251441
Aletler
Model
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC 272 daha göster
BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
Genel
Kahve makineleri, evde veya ticari ortamlarda pratik bir şekilde kahve demlemek için tasarlanmış cihazlardır. Her biri kahve telvesinden aroma çıkarmak için farklı yöntemler kullanan çeşitli tipleri vardır.
Türler
Damlama Kahve Makineleri
Pour-Over (Manuel Demleme) Kahve Makineleri
Pour-over kahve makineleri, kahve tutkunlarının demleme süreci üzerinde daha fazla kontrole sahip olmasını sağlayan manuel demleme cihazlarıdır. Temel tasarımı, kağıt veya metal bir filtre tutan huni veya koni şeklinde bir damlatıcıdan oluşur. Öğütülmüş kahve filtreye yerleştirilir ve üzerine yavaş, kontrollü bir şekilde sıcak su dökülür.
Otomatik Damlama Kahve Makineleri
Otomatik damlama kahve makineleri, kolaylık ve kullanım kolaylığı için tasarlanmış popüler elektrikli demleme cihazlarıdır. Otomatik damlama kahve makineleri, demleme sürecini otomatiğe bağlar. Hazneye su ekler, filtre sepetine öğütülmüş kahve koyar ve makineyi çalıştırırsınız. Su ısıtılır ve ardından kahve telvesinin üzerine damlatılır. Demlenen kahve bir filtreden geçerek bir sürahi veya demliğe akar; bu kap, kahveyi sıcak tutmak için bir ısıtıcı plaka üzerinde durur. Bazı modeller ayarlanabilir demleme sertliği ve zaman gecikmesi gibi özellikler sunar.
Demleme (Steeping) Yöntemli Kahve Makineleri
Soğuk Demleme (Cold Brew) Kahve Makineleri
Soğuk demleme kahve makineleri, soğuk demleme kahvenin basit ve verimli bir şekilde hazırlanması için tasarlanmış cihazlardır. Genellikle, kalın öğütülmüş kahve çekirdeklerinin soğuk veya oda sıcaklığındaki suda uzun bir süre, genellikle 12-24 saat boyunca bekletilmesini içerir. Sonuç, tüketilmeden önce su veya sütle seyreltilebilen, yumuşak ve daha az asidik bir kahve konsantresidir. Bu makineler genellikle telveyi ayırmak için bir filtre veya ağ sistemine sahiptir, bu da demleme işlemini pratik ve temiz hale getirir.
French Press
French press, basit ve etkili bir kahve demleme cihazıdır. Bir piston ve metal ağ filtre içeren silindirik cam veya paslanmaz çelik bir kaptan oluşur. Kahve yapmak için, kalın öğütülmüş kahve çekirdekleri press içinde sıcak suda bekletilir. Birkaç dakika sonra piston aşağı itilerek telve demlenmiş kahveden ayrılır. Demleme sürecinde kahve telvesi suyla doğrudan temas halinde kaldığı için bu yöntem tam gövdeli ve aromalı bir fincan kahve sağlar.
Türk Kahvesi Makineleri
Cezve veya ibrik olarak bilinen Türk kahvesi makineleri, Türk kahvesi yapmak için tasarlanmış geleneksel demleme kaplarıdır. Genellikle bakır veya pirinçten yapılan bu küçük kaplar, uzun bir sapa ve geniş bir tabana sahiptir. İnce öğütülmüş kahve, su ve şeker (isteğe bağlı) cezvede birleştirilir ve kısık ateşte ısıtılır. Benzersiz demleme süreci, karışımın birkaç kez kaynama noktasına yakın ısıtılmasını içerir ve "kaymak" olarak bilinen kalın bir köpüğe sahip sert, konsantre bir kahve oluşturur. İnce öğütülmüş kahve telvesi dibe çöker ve kendine özgü, zengin bir kahve deneyimi sunar.
Basınç Bazlı Kahve Makineleri
AeroPress
AeroPress, basitlik ve çok yönlülük için tasarlanmış kompakt bir kahve makinesidir. Bir piston ve filtre kapağına sahip silindirik bir hazneden oluşur. Kahve demlemek için kullanıcılar kahve telvesini ve sıcak suyu hazneye koyar, karıştırır, filtre kapağını takar ve kahveyi çıkarmak için pistonu bastırır. Benzersiz tasarımı hızlı ve kolay demleme sağlar; demleme değişkenleri üzerinde kontrol imkanıyla yumuşak ve zengin bir fincan kahve üretmesiyle bilinir. AeroPress; taşınabilirliği, uygun fiyatı ve farklı demleme teknikleri denemeye olanak tanıması nedeniyle kahve tutkunları arasında popülerdir.
Moka Pot
Moka Pot, buharla basınçlandırılmış kaynar suyu öğütülmüş kahveden geçirerek sert ve aromalı kahve demleyen bir ocak üstü kahve makinesidir. Su için bir alt hazne, kahve telvesi için orta bir huni ve son demleme için üst bir hazneden oluşur. Su ısındıkça, basınç onu kahve telvesinden geçmeye zorlar ve Moka olarak bilinen zengin ve konsantre bir kahve üretir. Süreç basit ve hızlıdır; espressoya benzer, kendine has tadı olan güçlü bir kahve yaratma yeteneğiyle popülerdir.
Tek Kişilik (Single-Serve) Kahve Makineleri
Tek kişilik kahve makineleri, porsiyonluk kahve demlemek için tasarlanmış kompakt ve pratik cihazlardır. Kullanıcıların minimum çaba ve kirlilikle tek bir fincan kahveyi hızlı ve kolay bir şekilde hazırlamasına olanak tanıyan önceden paketlenmiş kahve kapsülleri veya pedleri kullanırlar. Bu makineler, farklı damak zevklerine hitap eden çeşitli kahve seçenekleri sunar ve basitlikleri ile zaman tasarrufu sağlamaları nedeniyle tercih edilirler.
Espresso Makineleri
Genellikle espresso makineleri olarak bilinen espresso hazırlayıcılar, sıcak suyu ince öğütülmüş kahve çekirdeklerinden geçirerek konsantre kahve demlemek için tasarlanmış özel kahve cihazlarıdır. Kahve telvesinden zengin aromaları ve aromatik bileşikleri çıkarmak için genellikle 9 bar civarında yüksek basınç altında çalışırlar. Espresso, sert ve yoğun tadının yanı sıra üzerinde oluşan kremsi bir köpük olan krema tabakası ile karakterize edilir. Bu makineler manuel, yarı otomatik ve tam otomatik dahil olmak üzere çeşitli tiplerde gelir ve kullanıcılara demleme süreci üzerinde farklı seviyelerde kontrol sunar.
Tam Otomatik Kahve Makineleri
Tam otomatik kahve makineleri, kahve yapma sürecini kolaylaştıran gelişmiş cihazlardır. Bu makineler, kahve çekirdeği öğütmekten demlemeye kadar her şeyi halleder ve manuel müdahale ihtiyacını ortadan kaldırır. Bu makineler espresso, kapuçino, latte ve sade kahve dahil olmak üzere çeşitli içecekler üretebildiğinden, kullanıcılar öğütme boyutu, kahve sertliği ve içecek türü gibi faktörleri özelleştirebilir. Dahili öğütücüler ve otomatik demleme sistemleri ile minimum çabayla taze demlenmiş kahve sunarak kolaylık ve tutarlılık sağlarlar.
Percolator (Süzgeçli) Kahve Makineleri
Percolator kahve makineleri; bir demlik, merkezi bir tüp ve delikli bir sepetten oluşan geleneksel demleme cihazlarıdır. Demlikteki su ısıtılır ve oluşan basınç, suyu tüpten yukarı iterek sepetteki kahve telvesinin üzerine boşaltır. Demlenen kahve daha sonra istenen sertliğe ulaşılana kadar sürekli bir döngü halinde tekrar demliğe akar. Percolator makineleri geçmişte popülerdi ancak demleme yöntemleri ve tat tercihleri nedeniyle büyük ölçüde damlama kahve makineleriyle değiştirildi.
Sifon Kahve Makineleri
Vakum kahve demleyicileri olarak da bilinen sifon kahve makineleri, görsel olarak büyüleyici ve fizik tabanlı bir demleme yöntemi kullanır. İki hazneden oluşur; su alt haznede ısıtılır ve kahve telvesinin yerleştirildiği üst hazneye suyun geçmesini sağlayan bir buhar basıncı yaratır. Isı kapatıldığında, vakum etkisi nedeniyle demlenen kahve alt hazneye geri çekilir. Bu işlem, çekirdeklerin aromalarını ön plana çıkaran, yumuşak ve temiz tadıyla benzersiz ve aromatik bir kahve ile sonuçlanır.
Ek Bilgiler
Bu çevirmenlere özel teşekkürler:
100%
Gözde dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
