Ana içeriğe geç
The Kindle 3 was the 3rd generation of Kindle produced by Amazon. It was sold as a WI-FI or 3G model with 4 GB of internal storage.
How do I update web certificates?
When I turn on my kindle my screen tells me it cannot connect because it's out of date but I can't change the date because it's says the certicates are for a prescribe period of time and it cannot recognize my certificates. What can I do?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
SSL & https connections use a handshake process to validate who is who. The certificate authority controls the issuance of certificates which mostly update on their own.
Things that can effect this is if your devices date is not correct.
As an example the cert creation date is 2015 and expires 2018. Now your systems date & time setting is set for some reason to 2001 so your system is unable to use the cert as you went back in time from the certs perspective ;-}
Now lets say you set the date to 2019 so now your system still can't use the cert as from its perspective it expired!
So start off by making sure your data & time is correct on your Kindle. If you can, see if you can use the Internet time server option that way you'll always be on time (and date).
OK, still no joy what now? Your Kindle's likely needs an update Kindle E-Readers that Require Updates
Here's Amazons help web site for the Kindle: Kindle Keyboard Help
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Rene Pennington sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 3,185
