iPad Air 2 Randomly shutting down, red screen on boot up and shut down
Hi.
I replaced two iPad air 2 Digitizer's/Lcd on clients devices and on one of them, the device shows the Apple logo for about 10 seconds, goes red then shuts down. This loops.
It does boot at times into a fully working iPad which you can use but it again at times just turns it self off.
I did disconnect the battery so I'm wondering if I've got a bad connection?
Any suggestions would be appreciated.
Thanks
Bu iyi bir soru mu?
1 Yorum
I'm having the same issue after replacing the screen. No problems during repair, battery was disconnected prior to the new screen being attached. Sensor was soldered onto the new screen. No missing or damaged capacitors or diodes around the connectors. What was your solution?
Peter N tarafından
