Ana içeriğe geç
sylvania 32 watt octron 4100k
I have overhead kitchen lighting that takes 4 -1 inch by 4 foot of these bulbs. I replaced the bulbs but the lights won't turn back in. Breakers are all good. Any idea why they won't work ? The last bulb burnt out and was working. I replaced all 4 and they won't turn on. Help
Bu iyi bir soru mu?
Puan 0
1 Yorum
@mizart2u if you can let us know what model your light is and post some images of the light as well as the description marked on the old and new bulbs. Use this guide to add images Adding images to an existing question
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@mizart2u , Steve W, ensure you installed the correct bulbs for the fixture if indeed T8 fixture, T8 bulbs should be used. Make sure the bulbs had no protective end covers/plastic on them and are inserted properly. Check for power at the fixture with DVOM or non contact electrical tester, if no power switch or breaker could be bad. If you have power, correct bulbs and properly installed, either there is a bad connection to/from ballast or ballast is bad. Links below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.homerepairtutor.com/fix-your...
http://ask-the-electrician.com/fluoresce...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Steve W sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 667
