Ana içeriğe geç
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
37 Soru Tümünü görüntüle
My ABS light and TCS light are always on and engaged
My ABS and Traction Control light are always on, how can I fix this and are they absolutely essential or can I just turn them off. It will still pass NY state inspection with them on
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@dragonofaz , Matthew, Check all fuses and relays. Could be faulty wheel bearing/bad/loose wires/plug to ABS sensor or could be faulty ABS sensor, ABS pump motor faulty, EBCM faulty, etc. To help diagnose the issue better, have the vehicle scanned for error/diagnostic codes which may pin point the issue. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. See technical service bulletins (TSB) link below and links to a couple forums that discuss your problem.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ehow.com/list_7635921_problem...
http://www.tahoeyukonforum.com/threads/a...
http://www.tahoeyukonforum.com/threads/h...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Matthew PRicr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 50
Her zaman: 2,689
