Why bike wont start
I have a 2013 thunder bird 1600cc sometimes starts with no problem, and other times power to gages and fule pump but when i hit the starter nothing not even a click?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
@hectorpez ,Hector, That could be signs of a battery on it's way out or bad connection. Have battery tested, check all connections and wires for not being loose/corroded/damage in the starting circuit/on battery. See the link below as it discusses your issue. I have also attached a down loadable service manual at the 2nd link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 2,548
1 Yorum
Check for correct gap of sparkplug (s) and proper plug size
Robert Johnson tarafından
