No orange light when plugged into console
My Xbox One wont turn on and the orange light turns off when I plug the power bar in to the Console
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Presently working on a psu for xbox. Orange light goes off as soon as box turned on. This supply has a 5v standby supply and a 12v run supply. As soon as the run supply was activated, the ps shuts down. Thats because i found shorted transistors in the primary side of the run supply. This needs a competent technician to repair this. Looks like a surface mount capacitor has had some arcing across its surface. Mosfet defintely shorted.
Bu yanıt yardımcı oldu mu?
Can you give a bit more detail which transistors you are talking about that were shorted? Is this inside the PSU or the actual Xbox Motherboard?
This guide might help. Clean the brick with caned air when you put back together. Xbox One Power Brick (Day One Edition) Disassembly
And this guide might help to. Xbox One Motherboard Replacement
It sounds like a power issue the board might be shorted out so use a multi meter and check all solder marks and traces. Make sure they all get the right amount of power.
If you have any questions or concerns please comment below or email me at walker44805@gmail.com !
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
Kılavuz
Zorluk:
Orta
30 - 45 minutes
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 8,281
1 Yorum
Ya i have tried another PowerBrick and all it was doing was flickering orange
Vimpulse tarafından
