Ana içeriğe geç
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
2 small components next to u2 ic
Hi,
Anyone know what are the 2 components missing in the picture next to the u2 ic?
Ipad Mini A1432
Thank you in advance
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
They are two resistors used for the reverse voltage protection for PPVBUS, pretty sure you are going to need that:
http://prntscr.com/f4armo
To avoid issues with charging circuit.
R5705 is an 100 kiloohm resistor while R5706 is a 10 kiloohm resistor.
Location of resistors:
http://prntscr.com/f4asf7
Bu yanıt yardımcı oldu mu?
Puan 3
8 Yorum:
Thank you very much. Where can I get these, without buying a whole board?
tarafından
Usually at a place called mauser (not sure exactly what it's called) and digikey online.
tarafından
I'll give it a shot, thank you!
tarafından
I think those two spots use the same resistor, the 100K and 10K is just what the resistance between two points on the board should be.
Now if Minho would come and verify this that would be huge help. I would wait for his response before ordering those resistors.
tarafından
So are these capacitors or resistors? also the schematic you attached shows the numbers as R5705 and R5706 as opposed to R7505 and R7506.
tarafından
3 tane daha yorum göster
Yorum Ekle
If you have access to old, donor boards, you could harvest them. Otherwise, order them from Digikey.com or Mouser.com
You can get the 100K resistor here:
https://www.digikey.com/product-detail/e...
You can get the 10K resistor here:
I hope you realize that you are also missing C8191 which is very important.
Puan 3
3 Yorum:
Hi Minho,
Thank you for your response and the links.
I don't have old boards, so I need to buy them.
I removed C8191 because 1 of those resistors went under it while I was trying to save it lol and then it got lost again lol.
Those things are tiny :-|
Can I power up an iPad board with the DC Power Supply with OR without the battery being connected?
tarafından
You can connect a power supply to the battery terminals or if you use a charge cable, a battery needs to be connected.
tarafından
Thank you Minho.
tarafından
Yorum Ekle
Yanıtını ekle
Asher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 29
Her zaman: 550
