Ana içeriğe geç
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
73 Soru Tümünü görüntüle
How to make my phone work again?
My phone suddenly died. I was working normally on my phone then it suddenly went black.
The phone won't turn on again, and there is no indication of life at all.
Bu iyi bir soru mu?
Puan 1
2 Yorum
Have you cheaked your battery ?
tarafından
when I was playing Roblox and then when I was done I turned off my phone and when I turned it on again it said that stock android has stopped can you pls help me bc I really want to play Roblox again with my friend’s thanks
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Few things to try:
  • Verify that your phone has a sufficient charge.
  • Connect your original charger to your phone.
  • After a few minutes, try to turn on your phone. If it doesn't work, try another charging cable. Try mains and USB charging.
  • Verify that your phone, charging port, and battery contacts are not damaged.
  • Carefully inspect your phone's charging port and remove any debris.
  • Remove the battery.
  • Carefully clean and inspect the gold contacts on both the battery and on your phone.
Attempt a forced restart of the phone.
  • Press and hold the Power key for 30 seconds.
  • If the phone starts to power on, release the Power key.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
My phone works but doesn't go past the logo, it will then either stay stuck there or restarts itself
tarafından
my phone is doing the same thing
tarafından
My android phone won't let me call out or get phone calls help
tarafından
Yorum Ekle
Yanıtını ekle
Shay sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,699
