Ana içeriğe geç
Repair and support for the third generation of the Flip portable speaker by JBL.
The Charging PCB is destroyed. Any Solutions?
I know I shouldn't have, but when my JBL Flip 3's micro-usb charging port broke, I decided to take matters into my own hands. It's safe to say I destroyed the pcb that has the aux cord and charger. It's unusable. Is there anything I can use to replace this? I don't even need the aux cord, just the usb port. If i have to buy some cheapo charger pcb or make one myself, I'm down. It's a bummer to see this nice speaker end up in the junk drawer.
Bu iyi bir soru mu?
Puan 2
6 Yorum
Hi,
Don't know your speaker but is the charge port on a separate pcb from the main amplifier board?
If so, does the charge port pcb have a 'board number' printed on it at all?
If so search online using just the number only and see if there are any results.
Just a thought.
tarafından
It is a seperate pcb! but unfortunately I do not see any board number. Just a few markings like "C801" "j301" and "l205"
tarafından
@ez2remember70 add some images of the broken board with your question. Use this guide Adding images to an existing question for that so we can see what you see.
tarafından
Okay, Uploaded
tarafından
I did the same thing. Did you ever find a replacement? I've been looking all over the internet and I havent found anything.
tarafından
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello,
I had the same problem, just use the 4p cable for charging use the black - and red + for charging throug usb 5volt. You can solder a usb wire to it and it wil charge again! And then you can throw away that pcb!
Please let m know it worked for you too!?
Regards, Thiemo
Bu yanıt yardımcı oldu mu?
Puan 4
9 Yorum:
Hi,
I also wrecked the charging pcb and was about to throw away my JBL flip 3, then stumbled upon your comment and did exactly as you said. I now have a working and charging speaker with a usb wire permanently attached to it.
It has made me quite happy, thank you so much for your solution.
Best regards.
tarafından
Hi ,
I have a same problem with my jbl flip2
And i suddenly noticed your comment here .
Thanks a lot
And can i use a normal 5 A usb charger to solder with the board?
tarafından
Hello,
After soldering the USB cable to the speaker wires, I have plugged it in to a regular Samsung phone charger 5-9V and 1.64-2A I believe.
tarafından
It worked perfectly. Thank you so much for this comment. Usb male type A red and black to the the 4pin’s red and black, I left the other wires disconnected. The speaker charges and is functional like normal.
This might be possible too: the leftover 3 pin could be salvaged to connect a female aux for audio input. Have yet to try it, maybe for a future DIY project.
tarafından
Can anyone post a pic of the working solution please? The re-wire i mean :)
tarafından
4 tane daha yorum göster
Yorum Ekle
Here is a post about howw to fix the problem https://openclassrooms.com/forum/sujet/r...
Puan 0
Yorum Ekle
Yanıtını ekle
Sabastian Watson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 39
Her zaman: 16,684
