Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Why is my iPhone 6 cpu getting hot and phone does not power on after
why my iphone 6 cpu get hot and it does not power on after changing nand flash and eeprom. that phone is icloud lock bt i orderd the baseband +nandflash+ eeprom i sucsessfully changed nand epprom and baseband bt after that i power on the phone the cpu gets hot like !&&* please help me out...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The solder expanded under the underfill and created a short. You will need to replace the CPU now too. @refectio can probably explain it a lot better than I can lol
Bu yanıt yardımcı oldu mu?
Puan 4
45 Yorum:
That sums it up pretty nicely!
tarafından
if i will change my cpu then it will be get power on and everything will be fine after that ? and what about if i will reball the same cpu and fix it again please reply fast..
tarafından
If you Reball the CPU it will work.
tarafından
hey friend i tried removing the cpu and bymistake i removed the tracks that on logic board where where cpu balls set any idea how to fix it ??
tarafından
You will need aboard view to see what they go to, use PADS and a pcb file and click on the pad to see what it does.
tarafından
40 tane daha yorum göster
Yorum Ekle
hy, friends, i also meet this error about my iphone, i get many help from this forum, and also bought many DIY repair tools from china supplier (vipprogrammer.com), and still haven't fix this error,
Puan 0
1 Yorum:
The CPU is defective, Reball or replace and it will work.
tarafından
Yorum Ekle
Yanıtını ekle
zaid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 789
