Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
20 Soru Tümünü görüntüle
Touch ID Flex Cable Tore
Hello I was fixing the screen on my iPhone and being a bit too excited i tore the touch id flex cable not the one on the home button but the one that connects the button to the motherboard on a metal plate If i replace this will touch id still work
Cheers
Ben Cybulski :D
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yeah, absolutely. If for some reason Touch ID doesn't come back, then the cable is the issue. I.e. Bad cable. If everything with the home button is just fine
iPhone 6 Home Button Link Cable
Replace the cable that connects the home button assembly to the logic board compatible with the iPhone 6.  This cable follows a channel in the LCD shield plate. Görseli
Ürün
Bu yanıt yardımcı oldu mu?
Puan 7
4 Yorum:
Thank you so If i use the cable touch id will come back and the home button will work?
tarafından
Yeah, if it's just that cable, then you're good to go
tarafından
that cable is just an extension from the home button to the motherboard. if the home button is good touch ID and function will be working good.
tarafından
It doesn't come back because the flex cable is linked to the main board and so switching thecable will block the use of touch id
tarafından
Yorum Ekle
Yanıtını ekle
Ben Cybulski sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 846
