Will alcohol affect the Taptic-Engine?
I went to the beach and have salt water damage. I read alcohol was good to use but all the videos were on iPhone 6's and below so can I keep in the taptic-engine or take it out before I put it in rubbing alcohol?
Bu iyi bir soru mu?
2 Yorum
Avoid rubbing alcohol (it has all other kinds of chemicals that harm the logic board), use pure alcohol like isopropyl alcohol 90% or higher is best.
Ben tarafından
The taptic-engine is similar to a door bell an electromagnet moves a piston within to then strike the chime. Here its just a mass that is moved to give you the feeling of movement.
So yes any liquid that gets into it will damage it. So I won't immerse it just wipe it down.
Dan tarafından
