Ana içeriğe geç
Repair information and guides for saws, including circular saws, jigsaws, and scroller saws.
62 Soru Tümünü görüntüle
Why is it losing power? Where to buy parts?
Craftsman Model 315.172110 jig saw, it's losing power. I ASSUME the brushes need to be replaced. Not having much luck finding replacement brushes online. Anyone know, first, if this is the issue and second, where I can find a brush kit?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Dan Krier describe the "it's losing power" situation a bit better. If the brushes are worn then the jigsaw will not work. Not working means absolutely nothing working.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Dan Krier, I had the same result as you after doing a good search brushes discontinued and no alternative part listed. If need be, in the past I was able to order similar brush to what I required in a old saw(new brush was a little wider) so all I did was sand it down a bit to fit, reused old holder/spring and it worked very well. Below is a sample of brushes that are available for power tools. etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.ca/s/?ie=UTF8&keyword...
http://ohiocarbon.com/products/power-too...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Dan Krier sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 74
