Ana içeriğe geç
Water damage worth fixing
Phone was in water now won't turn on even plugged into charger. Has been sitting out to dry for 3 days. Is this worth fixing?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Lisa Francescangeli , Give it a try, nothing to lose really, using the tutorials below you can try repair yourself. Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd or 3rd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
iPhone 6 Teardown
Electronics Water Damage
Repairing iPhone Liquid Damage
iPhone Görseli
Kılavuz
Zorluk:
Zor
1 - 2 hours
iPhone 6 Görseli
Kılavuz
iPhone 6 Teardown
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Lisa Francescangeli I agree with @lpfaff1 but think there is a bit more to it. Yes, there is nothing for you to lose at this time, but there are a few details left out. Consider this an amendment.
The very first thing you want to do is to not try to restart/sync the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides. You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning 3/4 of the board. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for a 3G all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred missing or broken missing. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate.
Puan 1
Yorum Ekle
Yanıtını ekle
Lisa Francescangeli sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,014
